2000 Toyota 4Runner cracked yolk of frpont drive shaft
2000 TOYOTA 4RUNNER
2000FIXIT
Drive Train Axles Bearings problem
2000 Toyota 4Runner 6 cyl Automatic 160000 miles
The yolk of my drive shaft has cracked in the front. Can I weld it? Is this not safe? Can I replace it with a used one? How much would it cost to fix it?
Jul 29, 2010 at 10:01 AM
MERLIN2021
  • 17,250 POSTS
Welding is not a good idea, new or used replacement is OK.. You would never rebalance a welded part, and this will cause a bad vibration. Junk yard parts are cheap, but exact price is up to them... New if you can find one is probably in the 100-150 rANGE.
Jul 29, 2010 at 10:04 AM
