2000 Toyota 4Runner Check engine light
LARRY CRISWELL
Computer problem
2000 Toyota 4Runner 6 cyl Two Wheel Drive Automatic 113K miles
My check engine light came on recently. I went to local parts house and they hooked it up to the diagnostic reader. The read out said low fuel supply to left bank.The gentlemen there said that was not fuel filter or injector problems. Any ideas what this could be before i have to take it in to a professional?
Jul 20, 2008 at 12:16 AM
MASTERTECHTIM
  • 4,750 POSTS
he is a little off. lean supply on that bank. this is most commonly caused by a vacuum leak from a rubber hose, intake manifold gasket or even a oxygen sensor that is malfunctioning. hope this helps
Jul 20, 2008 at 12:37 AM
