2000 Toyota 4Runner Battery drain
2000 TOYOTA 4RUNNER
66,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEVON12
My 4-runner was transported from AZ to NY and we believe the driver somehow disabled the security system and since the we have a battery drain every two to three days if it is not driven.WE replaced the battery but are still having the same results
Feb 23, 2010 at 12:20 PM
  • 31,937 POSTS
Hi there,
You will need to get a current draw test done , this is where an Amp meter is placed between battery Pos (+) and the cable, with key off and doors closed this will show any excessive current draw, if above normal limits,(about .1=.15 Amps start pulling fuses to isolate the faulty circuit, also unhook the alt as a test as a faulty diode can also cause this, your mechanic should be able to do this test for you.
Mark (mhpautos)
Feb 23, 2010 at 1:40 PM
