1999 Toyota 4runner starter, ignition or alternator?
TALBOT2295
To Whom It May Concern:
Good morning!
I’m currently having difficulty with my Toyota 1999 4runeer when I go to start the vehicle. I put the key in and the car wont start and this does not happen all the time, I would say 2-times a week, but I do have electric power (lights, radio antenna ect), it just wont turn over until a few tries. I spoke to my neighbor who is a mechanic and he advised it might be the starter going bad, since electrical is functional and it clicks when I try to start. My concern is; I would hate for it not to be the starter and it is the ignition or even the alternator.
Your expertise and experience and advise to this issue is greatly appreciated.
Sincerely,
Andy
Apr 11, 2007 at 1:42 AM
BACKYARDMECHANIC
  • 337 POSTS
Dear Andy
From the information you provided I don't think it is the alternator. If it was then the battery would eventually go dead and the car would not start at all. Your neighbor could be right but, like you I hate to change parts without any reason or cause. I would first check the battery cable connections. More often then not this is the cause. Make sure they are clean and tight. If this isn't the problem then have the battery load tested. ( I don't know if temperature is a factor for not starting) You can get it done for free at some of the big chain stores like Sears ,auto zone etc. If this is good then when the car fails to start check that power is getting to the starter. This will eliminate the ignition switch, relays and the wiring to the starter. You can use a voltmeter or 12volt test lamp to make the test. If there is power then the starter is bad and needs to be replaced. To confirm this, those same stores will bench test the starter for you for free. Good luck :)
Apr 11, 2007 at 3:43 AM
BESTBET777
  • 89 POSTS
You need to get batttery tested, starter draw tested, altenator and regulator tested, all at once and repair or replace whatever's bad, all at once, each item can cause the other items to go bad in a short time.
Apr 18, 2007 at 9:57 AM
