1999 Toyota 4Runner Problem with starter turning over and o
DJDEBOLT
Electrical problem
1999 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
I went out this AM to start the truck and when I turned the key, the starter turned over, but the engine didn't start. When I removed the key, the starter continued to turn over until I disconnected the battery. The battery was hanging off the side of its pan. Is this ignition switch, starter solenoid or what else could it be??????
Jun 4, 2008 at 12:10 AM
BLACKOP555
  • 10,386 POSTS
i would suspect the starter solenoid is bad as the battery has fallen off of its stop, maybe kiked the line?
Jun 4, 2008 at 1:53 AM
DJDEBOLT
Thanks for the reply. I suspect the solenoid as well. Would you believe that a complete starter (with lifetime warranty) is cheaper than a replacement solenoid?? LOL
Jun 4, 2008 at 4:08 AM
BLACKOP555
  • 10,386 POSTS
crazy huh?
but the thing with starters is they are rebuilt soooooo without the core they would be around the same.
but still a little hunk of plastic is more then a starter.
Jun 4, 2008 at 1:02 PM
