1999 Toyota 4Runner Fan Clutch & Transmission Problem -
110,500 MILES • 6 CYL • 4WD • AUTOMATIC
MZNOBULL
Truck was overheating in hot weather, stop & go traffic only...dealer's svc center said it was the fan clutch & needed to replace (along with flushing radiator & thermostat etc)...as soon as i picked up, truck seemed like it drove like a tank (heavy feeling)...50 miles later the transmission failed with trans oil everywhere. DID THE WORK DONE AFFECT THE TRANSMISSION? Truck drove perfect prior...all maintanance done on time & at same svc center. Help!
Aug 23, 2010 at 12:21 AM
MZNOBULL
[quote:3c1d6c7e79="mznobull"]Transmission problem
1999 Toyota 4Runner 6 cyl Four Wheel Drive Automatic 110500 miles
Truck was overheating in hot weather, stop & go traffic only...dealer's svc center said it was the fan clutch & needed to replace (along with flushing radiator & thermostat etc)...as soon as i picked up, truck seemed like it drove like a tank (heavy feeling)...50 miles later the transmission failed with trans oil everywhere. DID THE WORK DONE AFFECT THE TRANSMISSION? Truck drove perfect prior...all maintanance done on time & at same svc center. Help![/quote:3c1d6c7e79]
Aug 23, 2010 at 12:27 AM
