1999 Toyota 4Runner Antenna
SWITCHBACKGRAPHICS
  • 1999 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 133,000 MILES
My antenna broke off just above where it exits the truck. I need to replace the mast only. The power portion of it has not worked in some time and I don't really mind that and don't want to bother fixing it either. What I do need to do though is replace the mast but don't want to remove the fender well to do so. What type of replacement mast do I need and how do I replace it once I have bought it?
Tuesday, May 6th, 2008 AT 1:54 PM
TEXASPETER
There is no way without removing a few bolts on the fender liner. Which can be done using a nut drive and about five minutes. Really simple
Monday, May 19th, 2008 AT 3:30 PM
DIYLOVER
You can get the power antenna mast from the dealer for about 35.00 dlls. this will do the job.
Here the link where tells you the step by step on how to replace the antenna mast.
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Wednesday, July 9th, 2008 AT 12:16 AM
