1998 Toyota 4Runner starter
1998 TOYOTA 4RUNNER
MANDUE
1998 Toyota 4Runner Two Wheel Drive Automatic 188,09 miles
how do you change a starter 1998 toyota 4runner
May 12, 2010 at 9:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
disconnect negative battery cable and remove right front tire. remove rubber mud cover. remove transmission check tube holding bracket bolt and remove tube. remove 2 brake line holding bracket bolts but do not disconnet brake line. remove wires connector and 2 bolts holding starter. twist starter to move it out. installation is reverse of removal procedure.
May 12, 2010 at 10:43 PM
