1997 Toyota 4Runner Water in the engine
1997 TOYOTA 4RUNNER
220,000 MILES • 6 CYL • 2WD • AUTOMATIC
ELIUNIVERSAL
I have a 1997 4runner limited and for the past three days i have been noticing the water out of the radiator very low. I will fill it up and the next day it was low again, and then i notice the truck started shacking and trowing lots of smoke out the escape. When i checked the the engine fluid it seen like it had some water in it, i think all of the water is going into the engine. What can i do or what should i do. Thank you for all your help.
Jan 16, 2008 at 12:41 PM
Get it block and pressure tested to rule out blown headgasket-it sure sounds like it.
Jan 16, 2008 at 3:12 PM
