1997 Toyota 4Runner starter
CBIGGS
Electrical problem
1997 Toyota 4Runner 6 cyl Four Wheel Drive Manual
my starter will not turn off unless i disconnect the battery, even with the key removed. we have had some problems with it it not wanting to start but i figured that it was the switch on the clutch pedal. the ignition switch also froze up once and i had to use graphite to free it up. don't know if this other info helps but i figured i'd throw it out there just in case. thanks
Sep 10, 2009 at 12:48 PM
  • 75,988 POSTS
Either you have a problem with the ignition switch or the starter relay sticking
Sep 10, 2009 at 1:07 PM
