1997 Toyota 4Runner knocking in motor
177,000 MILES • 6 CYL • 4WD • AUTOMATIC
FATTAPIG
I have a bad knocking in the back of my motor. I just had the oil changed the day before it started.When you first start it up when its cold the motor does not knock for about 5 minutes. Can anyone please tell me what to do . Thanks Danny
Feb 20, 2008 at 3:44 PM
  • 75,988 POSTS
Knocking noises is it a clicking/tapping/rapping/thudding/thumping noise-
Might want to check the oil pressure for a start. could be a clogged pick up screen/sludge/weak oil pump/engine bearings etc.
Feb 20, 2008 at 4:05 PM
FATTAPIG
Its more like a thudding, its bad enough that I am afraid to drive it. Should I try a motor flush? Thanks Danny
Feb 21, 2008 at 1:53 AM
  • 75,988 POSTS
You can try engine flush-don't work check the oil pressure. The knocking sounds like rod bearings
Feb 21, 2008 at 5:43 AM
FATTAPIG
I am going to check the oil pressure , Would it be rod bearings if it runs good for about 5 minutes at cold startup? Thanks again
Feb 21, 2008 at 5:57 AM
  • 75,988 POSTS
Could be who knows-knocking in the lower portion of the engine can be the rod or main bearings -check the oil pressure.
Feb 21, 2008 at 6:19 AM
