1997 Toyota 4Runner Fluid in driver side rear hub
27,300 MILES • 6 CYL • 4WD • AUTOMATIC
RANGFINSERV
My 4 runner has had a little bit of a loose rear end. The rear passenger tire is worn down the middle of the tire, no other tires are worn.
I pulled both rear tires and hubs. Everything looked good on the rear passenger side (the one with the bad tire), but on the rear driver side there is fluid all over the place. The fluid smells like deferential fluid. The rear breaks work fine and the break cylendar is not leaking.
I am assuming the loosness and the wear on the rear passenger tire are coming from an issue with the rear driver side...somewhere.
Any suggestions are appreciated.
Jul 28, 2008 at 7:00 AM
RANGFINSERV
I don't want to loose a wheel driving down the road.
Jul 29, 2008 at 10:11 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
The tyre wear in the middle of tyre tread is classic over inflation check the tyre pressures, as for the oil leak you will have to get the axle bearing & seal replaced the diff oil is leaking past the axle seal and flushing out the axle bearing into the brakes, this is a job not recommended for home mechanics as it can be extremely difficult to remove these bearings.
mark (mhpautos)
Jul 29, 2008 at 6:48 PM
RANGFINSERV
what is the price range I should pay to replace the seal?
Jul 30, 2008 at 5:01 AM
  • 31,937 POSTS
Hi there.
I will post a costing estimate when i get access to the data base later to day my time (Aust).
Mark (mhpautos)
Jul 30, 2008 at 10:33 AM
