1997 Toyota 4Runner engine bogging
180,000 MILES • 6 CYL • 4WD • MANUAL
DENIS1964
My 4runner seems to sputter, bog when I accelerate from 3rd to 4th, 4th to 5th gear trying to obtain higher speeds, and/or while driving up hill, check engine light came on and code suggested # 3 cylinder misfire. I have changed plugs, wires, O2 sensor, and it still does it. Also, tried fuel injector cleanor as well.
What do you suggest is the problem? I'm thinking of changing the fuel filter?
thanks.
denis
Jan 3, 2008 at 3:11 AM
  • 75,988 POSTS
Might want to check the fuel pressure while replacing the fuel filter and check injector/compression for cylinder 3
Jan 3, 2008 at 3:32 AM
  • 55,770 POSTS
Yep, the fuel filter can cause this problem, I would replace it first and then recheck the way the engine runs.
Dec 18, 2024 at 9:08 AM
