1997 Toyota 4Runner computer
MKJM
Computer problem
1997 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
my car was running ok.I stopped at store.attempted to start,however,car turned over then sputtered out immediately.Have attempted to replace camshaft position and crankshaft position sensors,after checking pressure on fuel pump,bad gas.Still same result.toyaota master tech says ground on computer or computer itself. Any suggestions?
Nov 1, 2010 at 11:28 AM
KHLOW2008
  • 41,812 POSTS
Hi mkjm,
What is missing causing the non starting, fuel or ignition sparks?
Nov 2, 2010 at 3:32 AM
MKJM
KHLow2008 thanks for reply.
answer fuel
Nov 2, 2010 at 1:47 PM
KHLOW2008
  • 41,812 POSTS
Did you test the fuel pump operations?
Is there any fuel pressure?
Other components to check are EFI relay and circuit opening relay.
What have been done so far?
Nov 3, 2010 at 12:55 AM
