1997 Toyota 4Runner check engine
121,000 MILES • 6 CYL • 4WD • AUTOMATIC
DHANOWA
chine engine light came on ,I check the code P0301 this mean Cyclinder #1 misfiring,I have changed spark plugs,coil, fuel filter,cleaned fuel injectors with machine,changed spark plugs wires,But I can not find the faults even the toyota dealer.Please help me.
Dec 13, 2007 at 11:02 AM
  • 31,937 POSTS
Hi there,
Clear the code and drive the car. Can you fell a miss fire? will it miss under load? Re check for code if gone all is well, if re set and you cannot feel any driveability problem, there may be a problem with the ECU qiving a fauls code. Often there are test units that you can use for a small fee to prove if there is a problem, your mechanic should be aware of the option.
Mark (mhpautos)
Dec 13, 2007 at 4:57 PM
