1997 Toyota 4Runner
1DANIKH
  • 1997 TOYOTA 4RUNNER
Transmission problem
1997 Toyota 4Runner 4 cyl Four Wheel Drive Manual
Hey mate, u know anything about clutches? I think my slave went today on the hilux. The piston in the slave has come out oil squirting out wen pushing pedel, but I should still be able to drive it with out a clutch. But. The clutch is still engaged ! It's like stuck in. Like someone is pushing in the pedel in? Any idea? Why is it engaged?
please email to Danik-1@hotmail. Com
or call 0415 877 222 adeliade
Optional Information:
Year: 1997
Make: Toyota
Model: ln106r
Engine: 2.8
Already Tried:
I just want to know why its stuck in nutral. And the clutch is engaged and if its more then a slave cylinder.
Tuesday, June 29th, 2010 AT 5:02 AM
KHLOW2008
  • 41,814 POSTS
Hi 1danikH,
If the slave cylinder piston is stuck, the clutch would be engaged if the fork is not allowed to return. It is similar to having the clutch pedal pressed when the hydraulic system is working correctly. You would have to remove the piston to allow the clutch release bearing fork to return to disengage the clutch.
Tuesday, June 29th, 2010 AT 12:48 PM
1DANIKH
Slave cylinder got replace. Still had the problem with not much clutch found out it was my clutch fork. It is cracked is it possible to chage a clutch fork in a gearbox with out taken out the box.?
Wednesday, June 30th, 2010 AT 7:24 AM
KHLOW2008
  • 41,814 POSTS
The transmission has to be removed to replace the clutch fork as it is looped over the clutch shaft.
Remember to check and if necessary, replace the bigot as it could get worn unevenly. Lubrication is of utmost importance.
Wednesday, June 30th, 2010 AT 9:15 AM
