1996 Toyota 4Runner wont run
RALPH BAWCOM
  • 1996 TOYOTA 4RUNNER
1996 Toyota 4Runner 6 cyl Automatic 175000 miles
my daughter ignition cylinder went out she drove car without it for 3weeks it shut thi fuel pump down how do wou get it going
Wednesday, January 28th, 2009 AT 8:03 AM
DOCFIXIT
  • 18,828 POSTS
Would you please expand post. Don't unerstand ignition went out she kept driving? Tell as much detail as you can
Wednesday, January 28th, 2009 AT 1:39 PM
RALPH BAWCOM
  • 5 POSTS
Ignition would only go to acc took cylinder out used plyers to start for ran 3 weeks replaced fuel pump and filter ran rough for about 5 miles quit now wont start replaced ignition cylinder still wont start what could be the problem if can help will make a small donation on feb 6 when I get paid
Friday, January 30th, 2009 AT 11:32 AM
DOCFIXIT
  • 18,828 POSTS
Assume no check engine light was on? Need to determine if you have lost fuel or ignition. Pull a plug wire hold next to block crank fire? If good spray some carb cleaner in intake start for sec?
Let me know
Friday, January 30th, 2009 AT 12:47 PM
RALPH BAWCOM
  • 5 POSTS
Plugs are firing it is ignition problem used start fluie it tried to start didn'tuse enough to make it run but it was firing
Friday, January 30th, 2009 AT 5:10 PM
Block the aiflow meter flap open and retry to start-tell me what happened-
Friday, January 30th, 2009 AT 6:51 PM
RALPH BAWCOM
  • 5 POSTS
Fuel pump not running checked fuses efi relay checked ok new fuej pump took it out ond it is ok checked wire mo power to pump what do you think thanks
Saturday, January 31st, 2009 AT 5:08 PM
Test the airflow meter and the circuit opening relay- the COR powers the fuel pump when the AF meter grounds the relay-
Saturday, January 31st, 2009 AT 5:39 PM
RALPH BAWCOM
  • 5 POSTS
Tested airflow meter didnot find circuit open relay put fuel pump back in finely got it started run rough try to go to passing gear it shuts down and at little above normal rpm it will shut down about to give up ond save enough money to put in in a shop thank you for trying so hara to help me get it going your crew is great
Monday, February 2nd, 2009 AT 4:40 PM
Not yet-Check the fuel pressure and idle air control valve and throttle position and coolant temperature sensor follow the repair manual then get back
Monday, February 2nd, 2009 AT 4:45 PM
