1996 Toyota 4Runner vibrates when accelerating or above 60
FUTTS78
Shakes or Wobbles problem
1996 Toyota 4Runner Two Wheel Drive Automatic 105000 miles
I have a 1996 Toyota Runner SR5. A couple of days ago I ran over a fist-sized rock going 30 mph. Since then it vibrates a lot when I'm on the freeway going over 55 mph. It vibrates when I accelerate at low speeds or when I go uphill, too. I thought the wheels might need balancing because it doesn't seem to be an alignment problem. My SUV had the front wheel alignment and all wheels balanced in 3/09. When I'm coasting or not accelerating it doesn't vibrate. The steering wheel vibrates a little but not much. Also, I noticed it seems hot under the hood or car after driving 20 min but the temperature gauge is in between Cold and Hot.
Aug 4, 2010 at 2:58 PM
FORDRACING24
  • 65 POSTS
If you haven't done an alignment or wheel balance in over a year you should get that done. Also besides a balance it could be your wheel bearings. Alignments are recommended every 20k miles or 1 year, and balances every 15k.
Aug 5, 2010 at 9:44 AM
