1996 Toyota 4Runner Key stuck in switch
250,000 MILES • 6 CYL • 4WD • MANUAL
POPPATOCK
Sometimes the key won't come out of the ignition. Toyo suggested a new key cut using VIN number as original key worn down. New key now stuck. Any suggestions?
Aug 28, 2008 at 6:44 AM
DOCFIXIT
  • 18,828 POSTS
Try some liquid graphite maybe it will free up. If not looks like new key cylinder is in order.
Thanks for your donation
Aug 28, 2008 at 7:00 AM
POPPATOCK
The key won't always turn to the lock position. It stops at "ACC".
Aug 28, 2008 at 7:14 AM
DOCFIXIT
  • 18,828 POSTS
Looks like cylinder replacement time.Will you be attempting repair yourself?
Aug 28, 2008 at 7:26 AM
POPPATOCK
I'd like to to save $$$$$. How difficult is this and will a cylinder from Auto Zone or Advance work?
Aug 28, 2008 at 7:33 AM
DOCFIXIT
  • 18,828 POSTS
Does truck have an air bag in steering wheel I think it does. If so this would be a little more than a DYI should tackle. But if you do it you'll need a good wheel puller and on this site On Line Repair Manuals will be helpful. Also OEM is the best way to go for key cyl
Aug 28, 2008 at 7:38 AM
