1996 Toyota 4Runner Key getting stuck in ignition
108,900 MILES • 6 CYL • 4WD • AUTOMATIC
GSMITH32
Ignition starts and turns vehicle off w/ no issues. Upon turning vehicle off, the key does not want to leave the ignition. It takes much jiggling to get to full off position where key can be removed. I had a new key cut but did not solve prob.
What is my next step of diagnosis?
Thank you
Jun 29, 2010 at 6:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
try lubricating lock cylinder with WD40 and work in the oil good with the key. if that doesn't help then most likely there is a fault with the shift interlock system.
Jun 30, 2010 at 1:57 AM
