Hi kravsteve, Welcome to 2carpros and TY for the donation
Jerking, Hesistating and Surging could be caused by the following:
Oxygen sensors.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
If it doesn't apply disregard it
SPONSORED LINKS
Thursday, March 25th, 2010 AT 6:01 PM
