1996 Toyota 4Runner ERACTIC IDLE
185,000 MILES • 6 CYL • 4WD • AUTOMATIC
RICHARD MAYO
MY 96 TOYOTA 4 RUNNER WHILE START TO REV UP TO 1500 TO 2000 RPM AT IDLE.WHEN THIS HAPPENS IF I CUT IT OFF IT IS HARD TO START. I HAVE REPLACED IDLE AIR VALVE AND PROBLEM IS STILL THERE. IT ALSO SEEMS TO REV UP AND DOWN SOMETIMES
Mar 2, 2010 at 7:11 AM
RICHARD MAYO
[quote:bdabeb5fe6="RICHARD MAYO"]Engine Performance problem
1996 Toyota 4Runner 6 cyl Four Wheel Drive Automatic 185000 miles
MY 96 TOYOTA 4 RUNNER WHILE START TO REV UP TO 1500 TO 2000 RPM AT IDLE.WHEN THIS HAPPENS IF I CUT IT OFF IT IS HARD TO START. I HAVE REPLACED IDLE AIR VALVE AND PROBLEM IS STILL THERE. IT ALSO SEEMS TO REV UP AND DOWN SOMETIMES[/quote:bdabeb5fe6]
Mar 3, 2010 at 2:56 AM
  • 75,988 POSTS
Hi RICHARD MAYO, Welcome to 2carpros and TY for the donation this is what keeps us going
Do you have a check engine light On and when was the last tune-up??
Check and test the EGR valve, throttle position sensor,mass airflow meter and also for vacuum leaks to include a fuel pressure check-
Mar 3, 2010 at 4:03 AM
RICHARD MAYO
I replaced mass air flow meter yesterday and it seems to be running okay at this time. When the problem orignally occured it was extremely cold. The temperature is a lot warmer now. i wonder if the temperature could effect this problem
Mar 3, 2010 at 4:15 AM
  • 75,988 POSTS
Check and test the coolant temperature sensor and also the cold start injector
Mar 3, 2010 at 4:17 AM
DOCFIXIT
  • 18,828 POSTS
Yes temp could be contributing ohm check Engine Coolant Temp sensor top rear of engine. see chart
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_371.jpg
ECT has Brown/Black and Green/Yellow wires
Mar 3, 2010 at 4:26 AM
RICHARD MAYO
I DONT HAVE A CHECK ENGINE LIGHT ON. BUT I GUESS BASED UPON THE AGE THAT SENSOR COULD POSSIBLY BE BAD.WILL CHECK RESISTANCE
Mar 3, 2010 at 5:14 AM
2 LINSEY
  • 287 POSTS
Hi, Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 5, 2010 at 7:27 AM
