1996 Toyota 4Runner Engine turns off
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADRI
Hello, this occurance happens at least 3 times thru out the day: When I turn the car key, engine turns on, but shortly right after it turns off. There are times that when I crank the key and give it gas so the car remains on, but once I release the gas pedal the RPMs start dropping until it turns off. After 3 to 4 tries, eventually the car will start up normal and stay on. Also related to the above, there have been times when I start the car, giving some gas and hear a popping sound from the engine...Please help me clear up my doubts and thank you.
Jan 13, 2008 at 7:51 AM
  • 75,988 POSTS
Check your fuel pressure with a gauge and comeback with the readings before I can continue this is where we start.
Jan 13, 2008 at 11:07 AM
