1995 Toyota 4Runner Transmission problem?
1995 TOYOTA 4RUNNER
139,000 MILES • 6 CYL • 4WD • MANUAL
JIM11895
When in first gear, the gearshift will occasionally pop out of first gear. There is never any problem putting it back into gear, and it doesn't pop out of the higher gears. Other than that the car shifts fine, and there are no problems shifting in or out of 4WD.
Is this a sign of a major transmission problem in the near future? Thanks for your help.
Jan 20, 2008 at 6:01 AM
MASTERTECHTIM
  • 4,750 POSTS
well it can be 1 of 2 things. the rubber boot that covers shifter at the floor can sometimes put pressure on shifter and pop it out of gear. if not that it is the synchronizer gear in transmission. hope this helps and it is just the boot. check back and let us know
Jan 20, 2008 at 9:42 AM
