1995 Toyota 4Runner TAILGATE WINDOW
1995 TOYOTA 4RUNNER
LSUDDUTH
Electrical problem
1995 Toyota 4Runner 6 cyl Two Wheel Drive Automatic
the glass in the tailgate will not roll down. I replaced the relay, the motor and the key switch. When we installed the new key switch the motor only turns 1 way. it will roll up the window, but not down.
May 19, 2010 at 10:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check the diode between the rear window switch and the front power windows circuit, should have white/red wire, red/back wire and red/green wire from it.
May 19, 2010 at 4:20 PM
