1995 Toyota 4Runner Replacement
FARRBEE
Brakes problem
1995 Toyota 4Runner Four Wheel Drive Automatic
In trying to remove the front tire, I have encountered a problem. I have removed all of the lug nuts but the tire seems to still be bolted on. Do I need to remove the hub bolts also? This is my Sister-in-law's vehicle and I don't have that much experience with Toyotas. Thanks
Aug 9, 2009 at 10:12 AM
  • 31,937 POSTS
HI there,
This will just be stuck on the hub, you should make sure that it is on stands and secure and safe, fit a wheel nut loosely, and lay down and kick the tyre left & right with your heels a few times, this usually dose the trick, but make sure it safely on stands and on firm level ground.
mark (mhpautos)
Aug 9, 2009 at 6:40 PM
