1995 Toyota 4Runner replace fuel oxygen sensor
136,000 MILES • 6 CYL • 4WD • AUTOMATIC
BOB80701
Replaced fuel tank due to rust and leaking fuel. Mileage went up to 21mpg. While under vehicle I noticed fuel oxygen sensor was bent and wires were broken. Replaced sensor and mileage went to 14mpg and timing is off. Disconnected sensor and check engine light is on but mileage is back up to 21mpg car runs fine. Where do I go from here? Will this damage the catalytic converter leaving the sensor unplugged?
Oct 10, 2008 at 6:02 AM
  • 75,988 POSTS
It will cause the engine to run rich at all times also ruin the catalytic converter.
Oct 10, 2008 at 6:11 AM
