1995 Toyota 4Runner problem with brakes
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
JLB4274
I've replaced/installed the wheel cylinder, piston calipers, brake pads, and brake booster.on my 4Runner. Why am I still losing braking power? When I hit the brakes, it feels like I have no brakes (I'm pushing the pedal to the floor). Thanks.
Apr 1, 2009 at 10:04 AM
  • 75,988 POSTS
If its not leaking anywhere-then you have an internal leak within the master cylinder seals/cups. Did you adjust the brake booster push rod as per the repair manual?
Apr 1, 2009 at 10:10 AM
WILLIAM OLIVER
  • 25 POSTS
did you replace the master cylinder with aftermarket part ? if so i recommend you to install a factory master cylinder , why did you replace the booster and cailiper ? well try factory master cylinder and see .
Apr 1, 2009 at 11:23 PM
