1995 Toyota 4Runner Fuel Pump Problems
212,000 MILES • 6 CYL • 2WD • AUTOMATIC
CAMRYE1
My 95 4runner quit on me going down the road. It will turn over with no problems. It is firing good but it acts like it isnt getting any gas. I replaced the fuel filter and when I did I turned on the key to see if the pump was working. I dont hear any noise from the pump but when you turn the motor over it will pump gas out of the lines. Will I need to replace the pump or is there some kind of sensor that could need to be replaced?
Feb 15, 2009 at 2:36 AM
  • 75,988 POSTS
Block the air vane flap open in the airflow meter and see what happens if it comes On test the airflow meter and circuit opening relay
Feb 15, 2009 at 3:49 AM
