feels like it is going to stall and there is a very strong odor of gas coming from the tail pipe and smoke coming from the tail pipe
Jan 3, 2009 at 9:02 PM
2CARPRO JACK
✓Experienced Mechanic
Sounds likeit has a misfire or rich condition. On the top front of the engine is a fuel pressure regulator. It has a small vacuum line that goes to it.See if there is any fuel in thesmall vacuum line, if so you need to replace it. If not, you may have an injector or possibly a bad plug or wire causing the rich condition/misfire.
