1995 Toyota 4Runner dies at idle
1995 TOYOTA 4RUNNER
206,000 MILES • 6 CYL • 4WD • MANUAL
NINJAMONKEY75
When in gear idles around 200rpm-400rpm almost always dying at stop lights etc... Idles fine in neutral. Im thinking its my iac but i cant find it. Is it possible its under my manifold?
Mar 12, 2010 at 2:47 PM
DAVE H
  • 13,384 POSTS
IDLE SPEED
A/C Idle-Up System
The A/C idle-up system provides a stable idle speed when A/C is operating. Engine Control Module (ECM) controls A/C idle-up valve which allows extra intake air to by-pass throttle valve for increased idle speed. The A/C idle-up valve is located in different locations. See A/C IDLE-UP VALVE LOCATIONS table. See Fig. 1 .
ApplicationValve Location
4-Cyl. 2.4LCenter Of Valve Cover & Contains 2-Pin Gray Connector
Auxiliary Air Valve
Auxiliary air valve provides additional air to intake manifold when engine is cold for increased idle speed. Auxiliary air valve is mounted on throttle body and determines engine temperature by engine coolant being routed around auxiliary air valve.
NOTE:Idle speed control system may also be referred to as idle air control system.
Throttle Opener (A/T)
Throttle opener, mounted on throttle body, is vacuum controlled and allows engine to return to specified RPM after throttle is released.
Mar 16, 2010 at 10:51 PM
