1995 Toyota 4Runner 4Runner runs rough while idling in gear
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
JANCIAUX
My 4Runner runs very rough occasionally while the vehicle is in gear and idling (i.e. at a stop light). Also, while accelerating, it seems to miss badly at around 2700 rpm. If I accelerate from there, it starts running stronger, but if I hold it close to that rpm, it will continue to miss. Further, (and I realize that this is a different problem) the transmission overheats and spits tranny fluid out all over the back of the vehicle whenever I pull my very small fishing boat for over an hour at highway speeds. (55-65 mph) When this happens is it better to turn the overdrive off and slow down a bit? Thanks in advance for any suggestions.
Apr 14, 2008 at 6:10 AM
2CARPRO JACK
  • 11,533 POSTS
It is a bad sign when an auto trans spits out fluid. Yes the OD should be off when towing. The misfire.... when was the last tune up? what parts did you use? Is th echeck engine light on? if so have the PCM scanned for codes
Apr 14, 2008 at 8:16 AM
