1995 Toyota 4Runner
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLIFFGUY
Recently my 4runner overheated. After stopping to allow it to cool I filled it with water and coolant only to discover a considerable amount leaking out the bottom. I can't see exactly where it is leaking from due to the skid plate. It continues to leak and overheat. I fill it with water everyday before heading out and luckily only have to drive a few miles. However it always overheats in just that short time. Also the heat does not work. I also experience an almost stall when the vehicle is cold and I press the gas to take off from a stopped position. As soon as I release the pedal the engine returns to idle speed with no apparent problem. If I allow the idle to get it moving and slowly press the pedal it sputters a bit but doesn't stall. Once It's warmer the problem disappears.
Jun 16, 2008 at 7:31 AM
KHLOW2008
  • 41,812 POSTS
Hi cliffguy,
If you don't get the leaking solved, if it is not already too late, you will live to regret.
Insufficient coolant can cause a lot of idling problem.
Jun 18, 2008 at 2:25 AM
