Break pedal hard (no assist at all). Engine runs fine, there was an issue with vacuum leaks but i think I have it solved. There is now vacuum at the booster. How much vacuum should be present at idle? can the booster go bad from prolonged loss of vacuum to it? What should the vacuum system pressure be?
Mar 2, 2009 at 2:43 AM
