1994 Toyota 4Runner throttle positioning switch
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
BERT D
Hi, I'am having a problem, here's my problem, I changed the throttle positioning sensor,spark plug,rotor and distribitor cap, when i went to start the car it would backfire threw the throttle body. It wouldn't stay at an idle either. I checked the timing and it is set at 10 degrees before TDC and the rotor is in the proper position on the distribitor. Please help me if you can, I'm stumped. Before I changed everything the car was running, it had very little power during acceleration but would run and get me where I had to go.
Thank You Bert D.
Feb 10, 2008 at 8:13 AM
  • 75,988 POSTS
Your sure you wired it correctly by firing order-if you did could be the sparkplug heat range- Test the throttle position sensor's closed and wide open throttle voltages-follow the book
Feb 10, 2008 at 8:51 AM
4RUNNINKDH
  • 5 POSTS
Dixon, is that you?
Feb 10, 2008 at 10:20 AM
