1994 Toyota 4Runner major short blowing 40 amp alt. fuse, &
120,234 MILES • 6 CYL • 4WD • AUTOMATIC
PAULJ0557
I am repairing my friends 4runner and there is an obvious short to ground, the 40 amp B+ fuse blows readily when the + terminal is touched to the battery longer than the time required to generate some sparks- it's almost enough to weld the terminal to the battery...so when disconnecting the B+ from the alternator bolt the symptoms of sparking goes away completely.
Also for some strange, and possibly related issue, the wipers are stuck ON and in one speed. adjusting the speed control to off or other positions makes no difference.
Incidentally, when trying to start the vehicle ( with the B+ unhooked from the alternator) it doesn't fire at all .
Thanks for any help. -Paul, in Ohio.
Sep 13, 2008 at 9:58 AM
WHITEWOLFTRIBE
My wifes 1990 4runner had the same problem except it was the 80 amp main that kept blowing then i tested the alt. and it had a short (open) and was exactly the same response you got. so check the alt.
As for the wind sheild wipers staying on it sounds like the regulator on the switch burnt when the 40 blew you might need to change it but check it first.
Oct 13, 2008 at 4:52 PM
