1994 Toyota 4Runner Heater Fan Motor Fuse?
248,563 MILES • 6 CYL • 4WD • MANUAL
PAUL VAL
Assuming there is a fuse for the fan blower motor, can anyone tell me where it might be located? The switch operates but the fan won't come on. Thank you very much!
Mar 20, 2009 at 6:39 AM
JAMES W.
  • 2,394 POSTS
Fuse should be #16 in the underdash fuse block. If this fuse is good, you will want to check for 12 volts at the motor itself.
Mar 20, 2009 at 6:52 AM
PAUL VAL
[quote:e9b905b19a="James R. Weizel"]Fuse should be #16 in the underdash fuse block. If this fuse is good, you will want to check for 12 volts at the motor itself.[/quote:e9b905b19a]
James,
Wow, what a quick response. I'll check that fuse this afternoon and thank you very much. I'm not sure about the quote part but thanks again?
Paul Val
Mar 20, 2009 at 7:00 AM
JAMES W.
  • 2,394 POSTS
There is also a speed control resistor in the heater box under the dash that is prone to burn out. If you want to send me your email address, I'll ship you a copy of the diagram.
Mar 20, 2009 at 8:37 AM
PAUL VAL
[quote:5410ef91d0="James R. Weizel"]There is also a speed control resistor in the heater box under the dash that is prone to burn out. If you want to send me your email address, I'll ship you a copy of the diagram.[/quote:5410ef91d0]
Jim,
It seems that I don't have enough posts to send you a PM with my email address. Any way that you can describe to me where that resistor is? Thanks in advance. I get the quote thing now, so "Don't fall in love because it can stick to your face!"
Mar 27, 2009 at 3:04 AM
JAMES W.
  • 2,394 POSTS
The blower speed resistor should be under the dash on the heater box with 4 or 5 fairly heavy wires going to it.
Mar 28, 2009 at 4:39 PM
