1994 Toyota 4Runner Engine miss, fuel consumption
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
SUTTONPAINT
I have owned this truck for about 6 months. My 4 runner sat for about 3 weeks after the blizzard. It ran fine during the storm and I didn't need to drive it when the roads cleared. I just drove it today and the truck started to miss at any speed. I checked under the hood and all vac lines are secure. I noticed that my mileage sucks really really bad (10 - 12m.p.g.'s at best) highway. Always hashad poor mileage. It has good power when it's warmed up. But it's like I have a load of bricks in it when cold. I was hunting under the hood and when I sqeezed off the vac hose that runs from under the air intake on the right rear of the motor, it smooths out. The line runs from a steel line from under the intake to a steel line that runs down the firewall. Fuel recovery?With 25 years of auto repair experience I am stumped. I had gotten out of the business 5 years ago and no longer have acess to diag equipment. The tune up is new and from the records I got when I bought it so is the t-belt. The thing is when I pulled off the afore mentioned hose with it running there is a steady stream of fuel squirting out from the intake side of the steel line. I suspect that this is where my mileage is going. But I am at a loss of the steady fuel stream. ( I mean 3-4 inches of fuel shooting out) This line is not in any Emission hose diagram Hope you can help. Thanks.
Mar 19, 2010 at 11:45 AM
  • 75,988 POSTS
You sure the fuel pressure regulator is not ruptured internally causing it to drop the mileage by feeding the vacuum hose to it with fuel
Mar 19, 2010 at 12:08 PM
