1994 Toyota 4Runner achieving 23 mpg, or more.
WORLDCLASSROCKS
Engine Performance problem
1994 Toyota 4Runner 6 cyl Four Wheel Drive
GREAT TO FIND THIS WEB-SIGHT,
I HAVE TEN MPG, TO DEAL WITH. I ADDED A CONTAINER OF "SEA - FOA ' TO TWELVE GALLONS OF UNLEADED GASOLINE. I HAVE HEARD OF AN OIL IMPREGNATED / COTTON AIR FILTER, TO IMPROVE AIR FLOW. ANY USEFULL SOLUTIONS ? 77,000, SHOULD BE BETTER, AS 'SMOG-TEST' RESULTS CLAIM PERFECTLY CLEAN RUNNING. THE "D" KICK-DOWN, ON STEEP HILLS IS NOT WELL ADJUSTED.
THANK YOU.
May 13, 2008 at 8:44 AM
BLACKOP555
  • 10,386 POSTS
10mpg?!??! such drastic decrease in mile huh? i would suspect a bad o2 sensor since its such a drastic drop to start things off or leaky injectors or bad fuel pressure pump and regulator.
THe air filter will maybe increase your mpg 2 miles at the MOST.
May 13, 2008 at 9:16 AM
