1994 Toyota 4Runner Dies when you give it gas
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
NATENIK
We have replaced fuel pump & filter. Not ignition related. Will start and idle but dies and will not start again until the next day.
Mar 20, 2008 at 4:04 PM
  • 75,988 POSTS
Check the actual fuel pressure with and w/o the pressure regulator, idle air control valve, exhaust recirculating valve, throttle position sensor and MAF sensor-
To confirm what's causing it to start and stalls-immediately check for spark and fuel when it dies out-one of this is gonna be missing then report back your findings.
Mar 20, 2008 at 10:39 PM
