when i put coolant into rad it steadily leaks out of the driver side rear of engine? need help and also torque specs for whole truck? thanks
May 5, 2010 at 6:55 AM
✓Experienced Mechanic
Hi there,
You will have to get the cooling system pressure tested to locate this leak, as for the torque specs, a full list is way to big to be posting here, what do you need in particular?
