Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
4Runner
Trouble Codes
1994 Toyota 4Runner Code 71
1994 TOYOTA 4RUNNER
123,000 MILES • 6 CYL • 4WD • AUTOMATIC
RJMARTINEZ
MEMBER
1 POST
What is the explaination of fault code 71?
Apr 1, 2009 at 12:54 AM
WILLIAM OLIVER
MEMBER
EGR system malfunction . ck for open in EGR gas temperature sensor circuit .
open in vsv circuit for EGR.
EGR vacuum hose disconnected valve stuck
clogged in EGR gas passage and last wich is very un normal to fail the ECM .
Apr 1, 2009 at 11:39 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
