1994 Toyota 4Runner clutch problems
20,000 MILES • 6 CYL • 4WD • MANUAL
ETHAN ODENBAUGH
i really need help! my clucth stared to stick to the floor, so i gota new spring and that fixed it. so now its hard to go into gear so i bleed the clutch and now my slave cylinder is not keeping the pressure i need so i got a new and now its still hard to put into gear i replace the clutch,pressure plate, and throw out bearing about a year ago. So can someone help me please?
Mar 1, 2010 at 1:05 PM
  • 75,988 POSTS
Could be the clutch master cylinder leaking internally -check and test it
Mar 1, 2010 at 1:11 PM
ETHAN ODENBAUGH
how could you check or test it?
Mar 1, 2010 at 1:22 PM
  • 75,988 POSTS
Get the adapter kit and bench test it-just like the brake master cylinder
Mar 1, 2010 at 4:37 PM
