Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
4Runner
Body
Sunroof
Stuck
Sunroof stuck open
1993 TOYOTA 4RUNNER
170,163 MILES • 6 CYL • 4WD • AUTOMATIC
MYDAILYBALANCE
MEMBER
1 POST
My sunroof is stuck open, is there a way to manually close it until I can get it to the shop?
Jul 28, 2008 at 2:26 AM
KHLOW2008
Experienced Mechanic
Hi mydailybalance,
Thank you for the donation.
To close the sun roof manually is possible only if the cause is not a mechanical issue, like a stuck motor, cables rails etc.
If it is an electrical problem, maybe we can help to try to solve it.
Did you check the fuses and relays?
Jul 30, 2008 at 12:31 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
