1993 Toyota 4Runner Leaky freeze plug
1993 TOYOTA 4RUNNER
14,000 MILES • 6 CYL • 4WD • MANUAL
DOSTRANDER
I have a slightly leaking freeze plug on the drivers side cylinder head, it is on the back side of the head (against the firewall). There is only about 3 inches of clearance thru there, should you be able to replace that plug without having to remove the head or lifting the engine?
Thanks
May 1, 2008 at 9:24 AM
MERLIN2021
  • 17,250 POSTS
I doubt it, but there is a freeze plug tool with an adjustable head on it. Problem is once you get the old one out...well you know!
May 1, 2008 at 9:26 AM
DOSTRANDER
[quote:075390c91d="merlin2021"]..... freeze plug tool with an adjustable head.....[/quote:075390c91d]
Could you point me in the direction of that tool? Also, how much pressure do you think it would require to press a new one in?
May 1, 2008 at 11:53 AM
MERLIN2021
  • 17,250 POSTS
You can buy it from Snap on tools...or try tour local auto parts store. When you see the tool it's kinda self explanitory...
May 1, 2008 at 7:34 PM
