I have a slightly leaking freeze plug on the drivers side cylinder head, it is on the back side of the head (against the firewall). There is only about 3 inches of clearance thru there, should you be able to replace that plug without having to remove the head or lifting the engine?
Thanks
Thanks
May 1, 2008 at 4:24 PM
