1993 Toyota 4Runner code 25 and 26
240,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALAINUYPO
code 25 and 26 , i have already replace the 02 sensor and the water temp sensor , i still have the same problem after clearing the code , i ahve also check the cold start injector reading ,02 sensor reading it seems to be working , engine runs rough and sluggish , I'm thinking about giving it a complete tune up , cap ,rotor, plugs , wires ,and also maybe the engine computer, please help any advice i will appreciate it , thank you
Jul 7, 2008 at 5:03 PM
KHLOW2008
  • 41,812 POSTS
Hi alainuypo,
25 and 26 = lean and rich mixture.
It has something to do with the rough running, engnine hunting.
I would suggest checking for vacumn leakages, high or low idling speed(throttle body clogged), IAC, MAP and spark plugs.
Should not be the ECM.
Jul 8, 2008 at 7:22 AM
