I have rear heat and it blows out fine, but my front heat does not blow out at all. Do you think it is the blower motor or the resistor?
Nov 5, 2008 at 5:52 PM
BMRFIXIT
✓ASE Certified Mechanic
Check fuses as a 1st step
place front heater on high locate blower motor and check for power and check for ground at the plug
if both OK replace blower motor
