Hi osusae,
Thank you for the donation.
The symptoms seems to indicate a problem with the trans assy rather than the solenoids.
Possible causes are the valve body or a pressure leak in the trans. Since the trans was recently replaced, it should be under warranty and I would suggest getting back to where the trans was replaced to check through. The replaced trans might be failing.
SPONSORED LINKS
Sunday, August 2nd, 2009 AT 1:27 AM
