1991 Toyota 4Runner transmission
JAE26
  • 1991 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 237,000 MILES
I recently bought a 1991 4 Runner for a couple of hundred dollars. I knew it needed work but I could not pass up the deal. My engine purrs like a cat, but when I engage the gear selector lever from park to any other gear, the vehicle feels as if the transmission engaged but it does not move either forward or back. I changed the transmission fluid and filter already. I ask if you guys can assist me with this issue. I have the money to drop on a mechanic, but I would like the experience of fixing this vehicle myself.
Wednesday, March 3rd, 2010 AT 10:00 AM
KHLOW2008
  • 41,814 POSTS
Hi jae26,
Thank you for the donation.
It could be a faulty transmission which requires rebuilding or replacement, a faulty drive train or transfer case.
Let us start by checking the drive trains. With gear in park on a level ground, release the handbrake and try to push the vehicle forward or back wards.
If vehicle does not move, the drive train is ok.
Wednesday, March 3rd, 2010 AT 12:05 PM
